DIAdem
Exporting Waveform Timestamps
I'm generating a bunch of tdms files which contain various datastreams anywhere between 1Hz and 50kHz.
However, I don't seem to be able to extract any Absolute timestamp information outside of Diadem, which correctly shows absolute and relative timestamps.
Opening the generated TDMS in MATLAB itself results in the data but no timestamps, exporting from Diadem into .mat or .csv results in data (each column of a different length) and again no timestamps.
[MATLAB tdmsinfo shows the # samples, but absolutely no datetime information what so ever]
I presume I need to use a script to get the waveform data out of Diadem with each channel's associated timestamps (Ideally relative or absolute) depending on what it is needed for.
However my google skills are failing me and I cannot find any examples of someone doing something similar.
Can someone provide some basic code that will export data from Diadem into a .MAT or .CSV with Absolute/Relative timestamps with the option to only export selected parameters?
Thanks.
Message 1 of 1
(734 Views)
