DIAdem
Exporting a channel from data portal to an already existing excel file
Hi all,
I am currenting working with a script in DIAdem 10.2, trying to export a channel containing 2 values to an already existing excel file using the following command:
Call ExcelExport(EXCELFile, EXCELSheet, EXCELDlgFlag, EXCELConfigFile)
I have basically 2 questions:
1)Upon the DIAdem help, the second parameter should be the name of the worksheet in Excel.  So I tried once with giving a name of the worksheet in an existing excel file and run the above command.  This command delete all the existing worksheets and add a new one under the name of "DIAdem" and export the data I wanted to.  The same happened when I don't give hany EXCELsheet in the above command.
(3,184 Views)
