DIAdem
Extracting indivicual cycles from a channel
I have a waveform from which I wish to extract each cycle and superimpose them and create a resultant graph.
It is a long process manually, using the band selection cursor for each cycle > copying the data points >plotting the copied channels, as shown below:
Original channel:original.pngIntended Result (showing 4 cycles only):
intended.pngI would like to know how to automate this process, if possible.
Thank you,
Jesu
(3,046 Views)
Hey,
You can use Find Pattern in ANALYSIS which was added in DIAdem 2017.
Load Pattern_Example.tdm file for a demonstration:
C:\Program Files\National Instruments\DIAdem 2017\Examples
Then open ANALYSIS --> Channel functions --> Find pattern
Or start this example which ships with DIAdem 2017.
Regards
Christian
CLA, CTA, CLED
(3,002 Views)
Hey Christian,
I am using Diadem 2015. I have been able to create a very rough workaround through scripting. Each cycle has a length of 23 data points. So I used a loop to extract each 23 point segment and store them in a new channel.
Jesu
(2,984 Views)
