DIAdem
Extracting system variable from .blf file
Hello everyone!
The case is the following: Using Bus Log Converter I want to extract from .blf file (or any other vector supported file), not only channels and its values but also system variables which are logged too. Is that even possible?
(3,352 Views)
I have worked with Vector .blf files, but never System Variables.  Any chance you can post a small file along with the .dbc file?
(3,292 Views)
Unfortunately, I cannot provide any of my .dbc files but to be honest it would not help because if I remember well system variables are stored in config.
Moreover, I do not need to use the .blf file, it can be any other log file.
(3,279 Views)
