DIAdem
FAMOS Data import in DIADEM fails with nonequidistant data
Import of Data in FAMOS-Format via plugin works fine with equidistant Data but fails with non-equidistant data. Error Message: "Unable to process part of the source file."  Is there a solution?
(2,622 Views)
Hi Yrchn,
There may be a solution, but getting to one will require that you submit the data set that's causing trouble to R&D.  The easiest way to do that is to navigate to the DataPlugins download page:
www.ni.com/dataplugins
... and click on the "Request a DataPlugin" link.  There you can describe the trouble and post the offending data file(s).  This link is designed to let customers request new DataPlugins, but it also works to request improvements to existing DataPlugins.
Brad Turpin
DIAdem Product Support Engineer
(2,582 Views)
