DIAdem
FFT Y-Output Values don´t correspond expactions regarding Input
Hi
i am quite stuck with this problem and could really need help:
my Situation right now:
- concatenated 121 files with each 21000 measurments each, to a torque channel ( MyR ) and a rpm channel( Rotspd ) via skript
- created a numerik time channel ( time ) starting a 0-72600s, with 2541000 number values based on the number of files and measurements.
- choose FFT (One Time Signal), Time channel: time, Signal channel: MyR, Window type: Retancle, FFT: Amplitudepeak, Average Amplitude:    None, Third/Oktave: No
( PIC: 1-3 )
my Problem:
after applying the FFT, i displayed the results and :
-the original measurment values&peaks do not correspond to the resulting amplitude peaks
i am using:
DIAdem 2015
15.0. (64 Bit)
How do i achieve the output values regarding peaks in my FFT output ?
Is there a better signal analyse funktion in Diadem besides FFT which results in Frequency(X) and Amplitude(Y) ?
Kind regards and big thanks in advance
Knicks
(3,089 Views)
Try selecting the top blank entry from the time channel scroll down in the FFT function
(3,070 Views)
Hey gsklyr
When setting the top entry blank, the channel has be to in Waveform which, after converting from a numerik channel, doesn‘t seem to change the result.
In your Project, a peak max value of Noise_3 is around 0.8 but after the FFT the resulting max value of Noise_3 is around 0.004.
So why is that, and how can i achieve a result with Frequency (X) and Amplitudepeak (Y) with fitting values ?
Appreciate your help in advance
Knicks
(3,043 Views)
Well the signal Noise_3 would be the sum of all the frequencies that make up this signal.  0.8 [Pa] seems to be a place where a lot of those frequencies intersect...  I don' think the output of the FFT function is bad
(3,035 Views)
