DIAdem
FUNCTION Procedure with optional inputs
Hello guys,
I'm looking for a way to create a function (UDF) with optional parameters, which can be set, but are not mandatory.
Just a simple example:
Function mean(a, b, c, {way})
Select Case way
 Case "geo"
  mean = SQR(a^2 + b^2 + c^2)
 Case ""
  mean = (a + b + c)/3
End Select
End Function
Here the function has the additional parameter, which is optional.
Is there any way to get this in Diadem?
Our current version is 2015.
(4,017 Views)
Accepted by topic author Dia791
There are no optional parameters in vbscript.
Either you need to handle null or there is a way to use an Array.
Option Explicit
function mean(byRef v)
  dim way : way = ""
  Select Case UBound(v)
    case 2
      ' nothing to do
    case 3
      way = v(3)
    case else
      err.Raise 100, "", "unsupported number of arguments"
  end select
  dim a : a = v(0)
  dim b : b = v(1)
  dim c : c = v(2)
  Select Case way
    Case "geo"
    Case ""
  End Select
end function
MsgBox mean(Array(1,2,3)) & VBCRLF & mean(Array(1,2,3, "geo"))
Potentially it is better to use multiple methods or a class
MsgBox new CMean.Calc(1,2,3) & VBCRLF & new CMean.Init("geo").calc(1,2,3)
class CMean
  function Init(byVal mode)
    set Init = me
    way = mode
  end function
  function Calc(byVal a, byVal b, byVal c)
    Select Case way
      Case "geo"
        Calc = SQR(a^2 + b^2 + c^2)
      Case ""
        Calc = (a + b + c)/3
    End Select
  end function
  Private Sub Class_Initialize()
    way = ""
  End Sub
  private way
end class
The advantage of the class Instance is that you can store it and have different implementations with the same interface.
(3,987 Views)
Thank you, Andreas!
The CLASS-solution is fine.
(3,984 Views)
