DIAdem
Failure ChnCorridor Runtime Error
i´m making a script in diadem, the data is a TDMS-File (3 GB data size).
I want to create a Corridor with the function ChnCorridor.
Now the failure accures:
Runtime error while "ChnCorridor"
Failure type: Unknown
Failure Adress: 00102FF2
Module name: KERNELBASE.dll
Maybe this are not the exact words, because I´m using DIAdem in German.
Can anyone help me with this problem?
Thanks in advance.
Andi
(1,815 Views)
Hi KB_User,
I have tested this with DIAdem 2020 and it works fine. Which DIAdem Version do you use?
Can you provide an example script with generated channel values and ChnCorridor command, so that I can try to reproduce the problem?
Greetings
Walter
(1,734 Views)
Hi Andi,
Are you using a 32bit version of DIAdem or a 64bit version of DIAdem?
Brad Turpin
Principal Technical Support Engineer
(1,709 Views)
