10-08-2007 03:05 AM
10-08-2007 11:18 AM
Hi Samosi,
My French isn't good enough to answer you with, but I believe I've understood your question. It sounds like you have a LabVIEW program which is streaming binary (IEEE-754) data to disk to a file with the extension *.rap, and you would like to know if it is possible to read this file into DIAdem directly. Is that right? I didn't get the attached *.rap data file, did you really attach it? That usually works on this forum.
Anyway, DIAdem will very likely be able to read your data file once we create a DataPlugin for it. Can you attach a VI that reads these *.rap files, or the VI that writes these *.rap files? It would also be useful to have several *.rap data files, preferably relatively small ones.
If it's a pretty simple file format, I might be able to help,
Brad Turpin
DIAdem Product Support Engineer
10-12-2007 02:48 AM
10-12-2007 05:30 PM
Hi Samosi,
I was able to write a DataPlugin for your *.rap binary data files. If you know the correct channel names of the channels, we could put that into the DataPlugin as well, but for the time being they simply get called "Ch0, Ch1..." up to the I32 value at the beginning of the *.rap file. Note that the DataPlugin code is only about 20 lines.
Brad Turpin
10-17-2007 03:29 AM
Hi Brad turpin,
The Dataplugin run corretly. Thanks for this dataplugin. For the channel name, it's not important because the channel isn't fixe. I have again other question. In the diadem, what is the maximum number of column and of row that I can read??The number of culumn and of row are limited or no? Can i put two files data in pursuit (continuation) in the channel table??
Thanks you.
10-17-2007 04:50 PM
10-19-2007 08:42 AM
Hi Samosi,
It is possible to load data from two files into DIAdem such that you append the data from file2 at the bottom of the data from file1. So if file1 and file2 both have N channels of length 4000, you end up with N channels in DIAdem of length 8000. There is an example that first shipped with DIAdem 10.1 called "Merging Channels From Different Measurements", or you can use the application I attached below for the same purpose.
Brad Turpin
10-23-2007 02:40 AM
