DIAdem
Filtering For Specific Data within a Dataset
Hello All,
A lot of the data I handle is recorded in 1Hz and there are specific conditions I would like to trend for obvious signs of change over the duration of a test. For example; if there is a section of a test cycle that has the identifier "Stage 7" and it is repeated multiple times within the cycle, I'd like to filter out for that specific stage so that I am left with a trend line.
The filter I am after will not limited to just stages, it would also be applicable to speeds, temperature ranges etc.
Is there a function for this?
Many thanks in advance.
(2,422 Views)
It is difficult to be sure about what you are looking for from your description, but perhaps an Event Search might work for you.  See this example:
http://www.savvydiademsolutions.com/blog.php?topic=blog-filter-channel-data-by-events
If that is not what you need, please provide a more detailed example.
(2,323 Views)
