DIAdem
Find number in a character chain
I got a character chain coming from an editbox
For exemple, the user put 12,4 or jaimelepate in the editbox
It return me the value "12,4" or "jaime lepate" (text form)
I want to check if the value is a text or a real number, then transform it into a real (I think this is done by Val("myvalue")
How may I check the type of value?
Thanks for your help
Fred
(5,590 Views)
Accepted by topic author fmanuel
Hi Fred,
You can check with IsNumeric(InputValue).
Brad Turpin
DIAdem Product Support Engineer
(5,573 Views)
The following example checks whether a variable is a number:
Dim MyVar
MyVar = 4711
Call MsgBox(IsNumeric(MyVar)) ' Returns True
MyVar = "4711"
MyVar = "No.4711"
Call MsgBox(IsNumeric(MyVar)) ' Returns False
Use <F1> to call the Help file of the method " IsNumeric " for VBS.
(5,562 Views)
Hello
Thanks I did it this way:
If(IsNumeric(Begin_Correlation_Time)) Then
Begin_Correlation_Time = Val(Begin_Correlation_Time)
else
Dialog_Box_Diagnostic_array(6) = "please select numeric values for correlation time"
end if
End Sub
 Best Regards,
Fred
(5,552 Views)
