DIAdem
Find/search GroupChannel/channel by code
I want to write function that search groupchannel/channel by pattern and gives the appropriate channels.
I can write function that loop all groupchannel/channel and check if the pattern contains in the groupchannel/channel name.
like search for : *Speed*
gives channels: * airSpeed*
                            *generalSpeed*
There is some DIAdem built in function that do it?
The same effect like the search channels windows above the data panel.(like windows 7 folder searching)
Thanks.
(6,058 Views)
Accepted by topic author OzShimon
Hi Oz,
Try this, it returns an ElementList of all the matching channels from all the groups.  You could alternatively put in a grouppattern/channelpattern as well.
Set MatchChannels = Data.GetChannels("*generalSpeed*")
jMax = MatchChannels.Count
FOR j = 1 TO jMax
  Msg = Msg & vbCRLF & MAtchChannels(j).Name
NEXT ' j
MsgBox Msg
Brad Turpin
DIAdem Product Support Engineer
(6,031 Views)
what format does that store the found channels in?
I want to do a search and then change the channel groups.
Call
Data.Move(Data.Root.ChannelGroups(found channel group).Channels("Found Channel"),Data.Root.ChannelGroups(4).Channels,1)
Basically, I want to move all channels containing the word "PRESS" to group 3 and all channels containing the word "FLOW" to group 4.  Right now they are scattered throughout different groups.
(5,779 Views)
Hi 2Pale4TX,
It sounds like this approach is what you want:
Set PressChannels = Data.GetChannels("*/*PRESS*")
jMax = PressChannels.Count
FOR j = 1 TO jMax
  Call Data.Move(PressChannels(j), Data.Root.ChannelGroups(3).Channels, j)
NEXT ' j
Set FlowChannels = Data.GetChannels("*/*FLOW*")
jMax = FlowChannels.Count
FOR j = 1 TO jMax
  Call Data.Move(FlowChannels(j), Data.Root.ChannelGroups(4).Channels, j)
NEXT ' j
Brad Turpin
(5,742 Views)
