DIAdem
Finding/Filtering Time Intervals with Value Conditions
I want to ask whether there is a feature allowing us to filter values in different channels in DIAdem.
For instance;
I have a data set being made up of Temperatue1 and Temperature 2. These's sampling rates are different. I am trying to search the times intervals where Temperature 1 is higher than 100 °C and Temperature 2 is lower than 30 °C. Is it possible with DIAdem?
Note: I do not mention about searching files with Data Finder. I am talking about searching time intervals with value conditions in my data set. However, If the case that I mentioned might be executed with Data Finder, I would want to use Data Finder, too.
Thank you.
Mehmet Subaşı
(2,141 Views)
Hi Mehmet Subaşı,
You can use the event search function for this. Define the single condition for each temperature and combine the conditions.
Greetings
Walter
(2,120 Views)
More examples of using DIAdem's powerful event search:
http://www.savvydiademsolutions.com/blog.php?topic=blog-filter-channel-data-by-events
(2,098 Views)
