DIAdem
Finding a Voltage Glitch
If someone could help, I would greatly appreciate it.
 I'm trying to find the time it takes for  the first voltage glitch ("Clutch Amps")  from when the "Clutch Voltage" drops .
Also the Voltage at the point of the glitch of the "Clutch Amps" .  Has anyone run into this type of problem before?
Thank you in advance for any help!
I have attached the  file and a graphic of what I'm looking to do..
Thanks  !!
SDuff
(4,700 Views)
Hello SDuf,
could you please post the complete TDM data set ? Its a pair of files. (TDM+TDX). The TDM file provides only the metadata.
Andreas
(4,686 Views)
Sorry ..Here they are.
Thanks for looking..
 I had to Zip the file....
SDuff
(4,666 Views)
Accepted by topic author SDuff
Hello SDuf,
please see the little script below providing a suggestion how to solve this :
Option Explicit  'Forces the explicit declaration of all the variables in a script.
Call LogFileDel()
Call Main()
Function Main()
  Dim     sgDataFile  : sgDataFile = CurrentScriptPath & "Clutch_do_sn001_02-19-2016_11-05-43-505.tdm"
  Dim     oGroupR,oChnSignal,oChnSmooth,oChn1Der
  Dim     FreqLimit,FilterDegree,oaEvents
  Call Data.Root.Clear()
  Call DataFileLoad(sgDataFile,"TDM","Load")
  Set oGroupR     = Data.Root.ChannelGroups.Add("Results")
  Set oChnSignal  = Data.GetChannel("Clutch (amps)")
  Set oChnSmooth  = oGroupR.Channels.Add(oChnSignal.Name&"_Smooth",DataTypeChnFloat64)
  Set oChn1Der  = oGroupR.Channels.Add(oChnSignal.Name&"First_Der",DataTypeChnFloat64)
  ' Preprocess clucth (amps) signal
  FreqLimit     =  100.
  FilterDegree  = 4
  Call ChnFiltCalc("",oChnSignal,oChnSmooth,"IIR","Bessel","Low pass",FilterDegree,FreqLimit,0,0,1.2,25,"Hamming",1,1)
  Call ChnSmooth(oChnSignal,oChnSmooth,50,"maxNumber")
  Call ChnSmooth(oChnSmooth,oChnSmooth,50,"maxNumber")
  '  calculate first derivative to then identify the area
  ' where the amps signal value decreases
  Call ChnDeriveCalc("",oChnSmooth,oChn1Der)
  ' pre-process derivative to better identify the area we're looking for
  Call ChnFiltCalc("",oChn1Der,oChn1Der,"IIR","Bessel","Low pass",FilterDegree,FreqLimit,0,0,1.2,25,"Hamming",1,1)
  Call ChnSmooth(oChn1Der,oChn1Der,50,"maxNumber")
  ' calculate area where first derivative is negative
  oaEvents = ChnEventDetectionWindow(,oChn1Der,NULL,-0.05,0.05,0.05)
  LogFileWrite("Intervall Indices:     "&oaEvents(0,0)& vbTab &oaEvents(0,1))
  LogFileWrite("Intervall time values: "&Str(oaEvents(0,2),"autoadj")& vbTab &str(oaEvents(0,3),"autoadj"))
End FUnction
(4,654 Views)
AndreasH_Ha
Thank you so much for your help. This works perfictly !!!
This Forum is always a great source of help!!
Thanks Again !!!!!!
SDuff
(4,630 Views)
