DIAdem
Finding temperature stabilization in 3 minute time intervals
I have an hour worth of data that I want to find when temperatures stabilize. My criteria is no more than 2degres rise in temperature over 3 minutes.  How can I break my entire run into 3 minute intervals and calculate temperature rise of each 3 minute intervals?
Message 1 of 8
(4,374 Views)
  • How many measurements do you take over 3 minutes? What is the accuracy?
  • What should happen if the temperature actually decreases over the time interval (e.g. heater failure)?
  • How much noise is in the data?
  • etc.
We can help more if we have more information, of course. 😄
Message 2 of 8
(4,355 Views)
I collected several different temperatures at a sample rate of 1hz(1 second).There is no noise in the data. The temperature does not decrease over time.
Message 3 of 8
(4,329 Views)
Hi Minnesota_Man,
You can calculate the delta values of the temperature channel first.
Then open the channel event function
Then set the parameters:
Channel: Delta
Event function: Window
Time channel: Time
Lower limit: 0
Upper limit: 0.1 (in your case 2 degres)
Use the filter function with an interval of 120 s (or 180 s for 3 minutes).
And calculate it.
The result is the channel EventStatus, which indicates with the first value grater 0 the beginning of the stabilization.
Greetings
Walter
Message 4 of 8
(4,313 Views)
What does calculating differences do? Whats the background calculation?
Message 5 of 8
(4,306 Views)
The function “Differences” calculates the difference between two consecutive single values in a numeric channel. With that you calculate the change of the temperature from value to value. If this change is below a limit (in your case 2 degrees) for a certain time (in your case 180 s) then the signal is stable. The function “Event Search” checks with the parameter “Window” whether the signal is below the limit and with the parameter “Filter“ when the time interval of 3 minutes is reached.
Greetings
Walter
Message 6 of 8
(4,296 Views)
something does not seem right still since the are shown shows stabilization. < 2F in a 180 second window
Message 7 of 8
(4,266 Views)
Can you please provide this dataset? Then I can have a look at it in detail.
Greetings
Walter
Message 8 of 8
(4,259 Views)
