DIAdem
First PicUpdate call opens DIAdem window
I try to automate some operations in DIAdem from LabVIEW with the connectivity VIs.  I try to keep DIAdem not visible on the screen all the time.  But on the first call of the PicUpdate() command, the DIAdem window opens.  I minimize it right after with "DIAdem Show Window.vi" but the user still have time to see the window.
The others calls of PicUpdate() don't brings up the DIAdem window...
What can I do to avoid this behavior?
Mathieu
(3,507 Views)
Hi Mathieu,
If you have DIAdem 10.0, I'm afraid you're stuck-- there was a bug of this type introduced in 10.0.  The good news is that it didn't exist before 10.0 and it has now been fixed in 10.1, which is due to release in a couple of weeks and is also available as a Beta version.  If you are using some version other than 10.0 and still see this problem, then let us know (and send us your VI)-- we should be able to change your code to make it go away.
Brad Turpin
DIAdem Product Support Engineer
(3,486 Views)
