DIAdem
Flags:Copy Data Points - Missing flags?
I'm using DIAdem 2012 to extract points from an FFT. Each time I use the "Flags: Copy Data Points" function the channels created are missing the last data point (flag). i.e. Channel contains n-1 points.
At the moment I'm adding an extra flag to ensure I copy all the flags I actually need but I'd apprcieate any advice, I may be missing something obvious... I've attached a screenshot.
Thanks in advance!
Padraig
(5,849 Views)
Accepted by pvitsligo
Thanks for posting. Can I confirm that you're able to set all of the flags that you need, but that all of these flags don't get copied? If this is what you're doing, are you then selecting more flags than required, then copying them all? You may need to look through re-selecting the flags and then copying them over again.
ShalimarA | CLA
(5,821 Views)
Thanks for your suggestion Shalimar,
Your correct that all of the flags were not copied. I've since tried the same method of adding/copying flags on new data and havn't had any problems, all the flags are copied so it seems the problem is corrected. It may have been an operator issue rather than DIAdem! Smiley Wink
Padraig
(5,817 Views)
Glad to hear that helped!
ShalimarA | CLA
(5,815 Views)
