DIAdem
For Loop Variable Problem
One of my user dialog boxes is made up of a table (Table1) that allows the user to provide values for data manipulation.  The script bellow is associated with the "OK" button of this dialog box.  It was written in DIAdem 10 and I am now trying to run the same script using DIAdem 11.1 (beta), because I want to use the new DRI (Dynamic Response Index) calculation function later in my scripts.
Sub OK_EventClick()
Dim This : Set This = OK
    L2 = TABLE1.Rows.COUNT
    'MULTIPLICATION
    mltcorfile = datadrvuser & "chnmlt.asc"
    If FILEX(mltcorfile) Then
        Call FileDelete(mltcorfile, 0)
    End If
    Call FILEWRITELN(mltCORFILE, 1, "MULTIPLICATION FACTORS")
    For I = 1 To L2
        R3 = TABLE1.Columns(2).CELLS(I).VALUE
        If R3 <> 0 Then
            T1 = TABLE1.Columns(1).CELLS(I).VALUE
            Call FILEWRITELN(mltCORFILE, 1, "(" & I & ") " & T1 & " = " & R3)
            '*****************DOES ACTUAL MULTIPLICATION OF DATA CHANNELS
            L10 = I
            T3 = CC(L10)
            T4 = CN(L10)
            T5 = CD(L10)
            Call FORMULACALC("CH(L10):=CH(L10)* R3")
            CC(L10) = T3
            CN(L10) = T4
            CD(L10) = T5
        End If
    Call filewriteln(mltcorfile,1, "END")
    'TRUNCATION
    trtcorfile = datadrvuser & "chntruncate.asc"
    If FILEX(trtcorfile) Then
        Call FileClose(trtcorfile)            'Ben added 11-10-06 to eliminate errors deleting the trtcorfile.
        Call FileDelete(trtcorfile, 0)
    End If
    Call FILEWRITELN(trtcorfile, 1, "TRUNCATION FACTORS")
    For I = 1 To L2
        L4 = TABLE1.Columns(3).CELLS(I).VALUE
        If L4 <> 0 Then
            T2 = TABLE1.Columns(1).CELLS(I).VALUE
            Call FILEWRITELN(trtcorfile, 1, "(" & i & ") " & T2 & " = " & L4)
        End If
    Call filewriteln(trtcorfile,1, "END")
End Sub
The error message I receive is with R3 (in the red text above):
Cannot assign value to a floating point variable
<R3 = >
Any ideas of where this error might come from woult be appreciated.  Remember that this script runs perfectly in DIAdem 10.
(4,828 Views)
H CrshTstr,
I can't explain why you're seeing the error only in DIAdem 11.1 and not previous versions, but the error message itself is quite clear.  The "R3" global variable is explicitly data typed as a Double/Real64.  The error message claims that you are trying to assign to this Real64 variable a value that can not be coerced into a Real64-- for instance a string such as "abc".  Try putting the following debug code in place of the current red command line:
On Error Resume Next
IF Err.Number <> 0 THEN MsgBox "I = " & I & " --> """ & TABLE1.Columns(2).CELLS(I).Value & """"
On Error Goto 0
That should highlight the problem,
Brad Turpin
DIAdem Product Support Engineer
(4,809 Views)
Thanks for the response, Brad!
I replaced my red line with your suggested text, but I'm still receiving the same error message...and I'm not getting the msgbox that is supposed to report the value of "i".  When I was working with it earlier I had set up a msgbox to output the value of "i" each time through the For Loop.  What I noticed was that the first time the msgbox came up i = 1, then the second time i = 0, and then I got the error message.
The table fields that are available for user input are all being left empty.  I'm not sure if this might be part of the problem as well.  We did have a bit more success (the script ran slightly further), when "0" were entered in all available table fields.
***EDIT*** I guess I wasn't saving my Dialog Box before running the script.  I thought it would work like scripts within DIAdem, where unsaved changes are still recognized.  Below are the outputs of the msgbox:
I=1 --> "1"
I=2 --> " "
Message Edited by CrshTstr on 06-16-2009 10:47 AM
(4,801 Views)
It seems I've found a workaround.  It turns out that the value of R3 when no data is entered in a particular cell in the table is " "...an empty character.  So I have added a line that sets R3 = 0 if the cell value is " ".  This seems to have taken care of the problem.  I'm sure there is a more elegant solution.
(4,793 Views)
Hi CrshTstr,
I'd recommend using the function "val()" to coerce the typed text to a real number.
Brad Turpin
(4,777 Views)
