DIAdem
Formatting (color) individual cells in a column2 of table and the criteria is referred from column 3.==> Using Diadem scripts.
Want to color the each cells in the column 2 with respect to criteria in column 3. If it satisfies the criteria, color it with green else color it with Red.
Sample expected output table:
Durai
Message 1 of 11
(2,426 Views)
Possible, you've to use the appropriate property node of the table control/indicator to set the BG Color individually by evaluating the values against the criteria. In the below image, I have demonstrated how to set colours for each cell, now you've to take care of evaluating the criteria to determine the colours.
Santhosh
Soliton Technologies
Message 2 of 11
(2,421 Views)
Hi Santhosh,
Thanks for your response.
I am actually trying to do it with Diadem scripts.
Do you have idea on that?
Message 3 of 11
(2,411 Views)
Apologies, I did not look at the board I am replying in. Unfortunately, I am not familiar with DIAdem to offer any help.
Santhosh
Message 4 of 11
(2,400 Views)
Hi Durai,
with DIAdem we ship an example called "Creating an Excel File" which shows how to set a cell color in Excel. The relevant part looks like this:
  set oCell = SetCellPair(oSheet, iRow, iCol, "Status: ", oGroups(2).Properties("Test~Status").Value)
  if uCase(oCell.Value) = "FAIL" then
    oCell.Interior.Color = iFailBGColor
    oCell.Font.Color     = iFailFontColor
  else
    oCell.Interior.Color = iPassBGColor
  end if
Greetings
Walter
Message 5 of 11
(2,365 Views)
Hi Walter,
Thanks for your reply.
I don't want to create a table in excel. Is there a way to do it in Diadem itself without use any external application?
I want to create a table in Diadem report based on channel values. And color the individual cells in a column2 with respect to column3 in the same table.
Everything want to do it in Diadem report sheet using scripts.
regards,
Durai
Message 6 of 11
(2,360 Views)
Accepted by topic author Durai26
Hi Durai,
Oops, I got something mixed up.
Yes, in a REPORT table you can change the background color of a cell with a user function. This user function can be defined for each column of the table. When drawing the table, the user function is then called for each cell value of the column so that you can adjust both the cell value and the cell parameters such as the cell color.
Here is an example:
“Using User Commands for Trend Displays in Tables”
Greetings
Walter
Message 7 of 11
(2,354 Views)
Thanks for the suggestion on user commands:
As per the example case, condition applies to a all the rows of column.
Is it possible to have individual condition for each row in a column?
sample:
Column 1: row 1: if value > 10, color by green
Column 1: row 2: if value > 5, color by red
Column 1: row 3: if value <> 1, color by red
Column 1: row 3: if value = 1, color by green
thanks,
Durai
Message 8 of 11
(2,298 Views)
Hi Durai,
Please have a look ate the help for "2DTableDrawingCellContext". There you find for the row:
Context.Row
Greetings
Walter
Message 9 of 11
(2,279 Views)
Is it possible to transfer variable from main script to user command?
User command:
if cell.value  > X then
    Cell.BackgroundColor.SetRGBColor(RGB(255, 0, 0))
end if
Value of X is needs to be transferred from main script  [VBS script] to user command.
X = A + B
A and B are values from channel.
Durai
Message 10 of 11
(2,162 Views)
