DIAdem
Frequency over time of a .REC signal
Hi everyone,
I am using DIAdem to analyse a sinusoidal signal provided by a "SEFRAM" device. This device provides me a .REC file.
The particularity of a .REC file is that there is no time channel.
I would like to plot the frequency over time and the frequency over amplitude. I've tried the function "Order analysis (frequency domain)" with no succeed.
Does someone have some advices ?
Thank you !
(769 Views)
Hi Paul,
is the problem the missing time channel or the frequency calculation?
If it is the first point, then you could create a time channel based on the waveform information on the extended properties section
with the function "Generate Time Channel". In your screenshot is mentioned a start date, the step width and the channel length.
(720 Views)
