DIAdem
Function DDC_SaveFile(..) from the DIAdem Connectivity Library failed
Dear Sirs,
I'm a member of a software development project-group under the leadership of the 'German Aerospace Center' (DLR) in Berlin/Germany. Inside this project we are using the actual 'DIAdem Connectivity Library' (nilibddc.dll version 8.6 with added support for timestamps) from National Instruments for management of our data. We first contact the DIAdem Product Manager, Caroline Bright, from NI to solve our problem, but she suggested to contact the support team from NI.
Here's our problem:
It seems that inside the actual release of the DIAdem Connectivity Library there are some limitations concerning the API-function 'DDC_SaveFile' operating on a newly created TDMS-file (DDC_CreateFile). The documentation gives no further limitations on using DDC_SaveFile, so we assume we can use it at every point of constructing our TDMS object-hierarchie. That means we create new groups/channels/properties 'on demand' mixed with callings to DDC_SaveFile based on programmatic issues. Unfortunately under specific circumstances 'DDC_SaveFile' failed (with simply "The file could not be saved", that helps not much), e.g. adding new groups/channels after a previous call to 'DDC_SaveFile'. It looks like that not all error-free constructed TDMS object-hierarchies could be saved correctly. Additional information are given in a log-file produced from the library. There you can found logs like the following:
"ERROR: TDS Exception in GetProperty: Tds Error: TdsErrObjectTransactionPending(-2530):
It would help us a lot if you could bring a little bit clarity to this obscure point.
Thank you very much
Thomas Zecha
Message 1 of 11
(7,954 Views)
Hello Thomas,
can you please provide a code snippet which can reproduce the error you reported to
stefan DOT romainczyk AT ni DOT com
Thanks and greetings from rainy Aachen
Stefan
Message 2 of 11
(7,931 Views)
Hi Stefan,
thank you for your response!
Here's the code (It is an extract of order/parameter-seetings of DDC_.. functions called by our high-level TDMSFilter-Library, so it looks somewhat strange, nevertheless it is equivalent and produces the error):
I have checked that there are no empty channels/groups are saved.
void
vReproduce_DDC_SaveFile_Error_v2()
DDCFileHandle hfile;
DDCChannelGroupHandle hgroup_data_packet;
DDCChannelGroupHandle hgroup_operation_hk;
DDCChannelGroupHandle hgroup_science_hk;
DDCChannelHandle hchannel_data_packet_pck_stream_1;
DDCChannelHandle hchannel_data_packet_index_pck_stream_1;
DDCChannelHandle hchannel_operation_hk_mertis_mode_1;
DDCChannelHandle hchannel_science_hk_tec_temperature_1;
int ires;
unsigned int iexist;
unsigned __int64 uinum_data_values;
unsigned int iindex = 0;
unsigned short xusdata[4096];
// this code produces error-code 'DDC_CouldNotSaveFile' in the last call to DDC_SaveFile(..) under MSVC 2003
ires = 0;
ires += DDC_CreateFile(
"test.tdms", "TDMS", "test", "test", "test", "test", &hfile);
ires += DDC_AddChannelGroup(hfile,
"DATA_PACKET", "", &hgroup_data_packet);
ires += DDC_AddChannel(hgroup_data_packet, (DDCDataType)2,
"pck_stream:1", "", "", &hchannel_data_packet_pck_stream_1);
ires += DDC_CreateChannelProperty(hchannel_data_packet_pck_stream_1,
"index_type", (DDCDataType)23, "indirect");
"index_name", (DDCDataType)23, "index_pck_stream:1");
ires += DDC_AddChannel(hgroup_data_packet, (DDCDataType)3,
"index_pck_stream:1", "", "", &hchannel_data_packet_index_pck_stream_1);
ires += DDC_ChannelPropertyExists(hchannel_data_packet_pck_stream_1,
"generation_timestamp_name", &iexist);
"generation_timestamp_name", (DDCDataType)23, "time_generation:1");
"storage_timestamp_name", &iexist);
"storage_timestamp_name", (DDCDataType)23, "time_storage:1");
ires += DDC_GetNumDataValues(hchannel_data_packet_pck_stream_1, &uinum_data_values);
ires += DDC_AppendDataValues(hchannel_data_packet_index_pck_stream_1, &iindex, 1);
ires += DDC_AppendDataValues(hchannel_data_packet_pck_stream_1, xusdata, 25);
"OPERATION_HK", "", &hgroup_operation_hk);
ires += DDC_AddChannel(hgroup_operation_hk, (DDCDataType)2,
"mertis_mode:1", "", "", &hchannel_operation_hk_mertis_mode_1);
ires += DDC_ChannelPropertyExists(hchannel_operation_hk_mertis_mode_1,
ires += DDC_CreateChannelProperty(hchannel_operation_hk_mertis_mode_1,
ires += DDC_AppendDataValues(hchannel_operation_hk_mertis_mode_1, xusdata, 1);
ires += DDC_SaveFile(hfile);
// obscure: commenting the next line let the last call to DDC_SaveFile(..) be error-free
"SCIENCE_HK", "", &hgroup_science_hk);
ires += DDC_AddChannel(hgroup_science_hk, (DDCDataType)2,
"tec_temperatur:1", "", "", &hchannel_science_hk_tec_temperature_1);
ires += DDC_ChannelPropertyExists(hchannel_science_hk_tec_temperature_1,
ires += DDC_CreateChannelProperty(hchannel_science_hk_tec_temperature_1,
ires += DDC_AppendDataValues(hchannel_science_hk_tec_temperature_1, xusdata, 1);
ires += DDC_CloseFile(hfile);
Greetings
Thomas
Message 3 of 11
(7,911 Views)
Hi Thomas,
in the current version of the TDM-C-DLL appears to be a problem when directly calling DDC_AppendDataValues after DDC_SaveFile.
You can work around that problem by inserting a call to DDC_GetFileProperty after DDC_SaveFile and before you access any other data in that file.
Greetings from sunny Aachen
Stefan
Message 4 of 11
(7,841 Views)
I have the same problem as Thomas. All 10 seconds I want to save the collected data. But every call produced the failure "ERROR: TDS Exception in GetProperty: Tds Error: TdsErrObjectTransactionPending(-2530)". I've added also the DDC_GetFileProperty call after DDC_FileSave. But it doesn't change anything. I'm using the DDC library version 8.6.
Does there exist a new library, which has fixed the problem?
David
Message 5 of 11
(7,377 Views)
This is an old topic. Using the latest TDM C DLL, and I am also doing "SaveFile" between each appending data call. Has anyone figured out how to solove the  "ERROR: TDS Exception in GetProperty: Tds Error: TdsErrObjectTransactionPending(-2530)" ?
Message 6 of 11
(3,764 Views)
Hello have you found a solution to this topic, I see they recommend to use this Get_FileProperty. Do you have any information about it, how to use it actually and is it actually solving the issue.
Message 7 of 11
(1,752 Views)
No documentation or example on this. To me this is a bug in the library file. Lack of support from NI too.
Message 8 of 11
(1,740 Views)
No documentation or example on this issue. The examples only cover the very basic. To me this is a bug in the library file. Lack of support from NI too.
Message 9 of 11
(1,739 Views)
Interesting and are you aware if this is causing some data to be corrupted or missmatching, since as far as I had looked into my case, everything seemed fine, besides of this bug log that I get
Message 10 of 11
(1,731 Views)
