DIAdem
Get list of channel properties / check if a property exists
Hallo, I need to check if a channel has a property with a given name, and in case create it. I try the following code but did not work, any hint?
               If oChn.Properties("prop_name").Exist = TRUE Then
(2,426 Views)
If oChn.Properties.Exists("prop_name") Then
http://zone.ni.com/reference/en-XX/help/370858M-01/inavidata/methods/diacmpnt_method_exists_idiademp...
No need to clutter with " = TRUE " unless it is easier for you to read
(2,408 Views)
