DIAdem
Getting a String from a selected path
I have the following piece of code in my script (which works fine)
dim result : result = DirListGet("C:\","*.adf","filename","FullFileNamesRecursive")
Instead of just using the "C:\" directory, I would like to prompt the user to choose one.
I tried using Application.DlgPathSelect  as well as PathNameGet to select a path, but I don't know how to put a String representation of the selected path into the DirListGet method above.
Thanks in advance,
Omar
(4,881 Views)
Accepted by topic author Meky
Hello Omar,
use it like this
if "IDOk" = PathDlgShow("Select a directory for adf files", "C:") then
  dim result : result = DirListGet(OutPutPath,"*.adf","filename","FullFileNamesRecursive")
end if
Greetings
Andreas
(4,878 Views)
