DIAdem
Graphic with degree scale for GPS acquired data
Hi everyone.
My issue: I have data acquired with Diadem 8.1 from a GPS receiver thru a NMEA protocol. (*.atr) file.
The coordinates "Latitude" and "Longitude" have the following strings: 'ddmm.ssss'.
My problem: There is no degrees Y scale in Diadem to plot these data. So when I have a GPS coordinate eg.: Latitude: 22°59'5999" (in Diadem = 2259,5999) the next row will be 23°00'0000" (in Diadem = 2300,00). As the 2D chart has only linear
Y scale, the signal has a displacement from the value 2250 to 2300. This changes the signal scope absolutely from the original test track.
The attached file can make things more clear.
Question 01: In Diadem 8.1, there is no chances of having a Y axis with scale in degress, isn`t it ?
Question 02: In VIEW mode, is there a chance to performe an autosequence in order to make calculation in the signal, by using the band cursor, so I could select a part of the signal and make an increment/decrement (+/- 40)  in order to concatenate the displaced signal ?
Perhaps the attached file could clarify the post.
Thanks in advance for any tip.
Rodrigo
Sao Paulo - Brazil
(3,756 Views)
Hello Rodrigo!
Answer Q1: As far as I know is there no chance
Answer Q2: I dont't think that this is the right way. I would recalc the input data and norm the minutes from a 0-59 range to a 0-99 range. The following script shows how to do it. To make the data flow clear I splitted it in more steps then necessary. You can put the code in a procedure and perform it for both input channels.
' : 100 to get the minutes to decimal places
Call FormulaCalc("Ch('Result1') := Ch('YCop_Latitude') / 100")
' get the decimal places only
Call FormulaCalc("Ch('Result2') := Frac( Ch('Result1') )")
' Input data without minutes (for later use)
Call FormulaCalc("Ch('Result3') := Ch('YCop_Latitude') - (Ch('Result2') * 100)")
' norm minutes from 0-59 to 0-99
Call FormulaCalc("Ch('Result4') := Ch('Result2') * 100/60")
' add the minutes back to the input data -> linear data
Call FormulaCalc("Ch('YCop_Latitude_Linear') := Ch('Result3') + Ch('Result4') * 100")
' delete the temporary channels
Call ChnDelete("Result1")
Call ChnDelete("Result2")
Call ChnDelete("Result3")
Call ChnDelete("Result4")
Hope this helps
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,742 Views)
Hi Rodrigo,
Or you could do the same transformation as Matthias suggests, but to pi radians instead of degrees.  The main thing is to transform your data into a range of continuous numbers, instead of having 3 separate numbers encoded in the numeric value that DIAdem is trying to plot.  We're up to DIAdem 10.1 now, and there is no dedicated degrees-minutes-seconds plotting.
Brad Turpin
DIAdem Product Support Engineer
(3,726 Views)
Once again, problem is solved.
The functions "Frac" and "Trunc" were helpfull !
Thank you very much Sirs.
RodrigoSmiley Wink
Sao Paulo - Brazil
(3,715 Views)
