DIAdem
Hardware in the loop/ Script serial output
I am working right now on a solution for my problem: I want to check sensor channel for a certain limit value WHILE measuring.  If the value measured exeeds the given limit it should send a serial output "1" to a COM port. I wanna use DAC script driver for this.
My problem right now: I have no clue how to get and work with the data from the sensor channel with delay, as little as possible.
What I got already for the Output:
Dim oSerialPort
' Initialize COM port
Sub SFD_Init( DeviceParam1V, DeviceParam2V, ErrorP )
  'Open and initialize object
   Set oSerialPort = CreateObject("DIAdem.SFD.UDI")
  'open the serial port (COM10)
  Call oSerialPort.Open("COM", "COM10")
  'set the baud rate (here 9600 baud)
  Call oSerialPort.ParamSet( "BAUDRATE","9600")
End Sub
' Error
Sub SFD_DeInit(ErrorP )
  ' close the COM port
  oUDIM.Close()
  ' and release the UDI object
  Set oUDIM = Nothing
End Sub
'Main
'Take the newest value from data channel. If value > 15 write "1" to serial COM port
pressure_measured =
   While pressure_measured  > 15
	Call oSerialPort.Write("1")
   Wend
' Close port
oSerialPort.Close()
 'Delete object :
  Set oUDIM = Nothing
End Sub
Thanks for your help!
Message 1 of 1
(2,245 Views)
