DIAdem
Help reading file into Diadem
I have a plugin made from a plugin wizard and I am trying to edit the plugin so that I can add Properties to Airflow Data. The script currently works but does not read in Airflow Test input
(2,820 Views)
Hi Tevin,
Here's a custom DataPlugin I created that loads that one data file and looks up the properties in the other Excel file, assuming it's always called "Airflow Test Input.xlsx" and located in the same directory as the data file.
Brad Turpin
DIAdem Product Support Engineer
(2,768 Views)
