DIAdem
Highlight one value in 2D Axis System
Hello all,
I would like to highlight a certain value (lets say value no. n) in a 2D axis system with a circle (DIAdem 9.1). Is that possible at all?
Regards
Patrick
(3,917 Views)
Hello Patrick!
Marker on the curve are one aproach to your problem. Unfortunately DIAdem isn't able to show one marker at a certain point! What you can do is to allocate two new channels with just the X/Y value pair and show this as a second curve with the marker you want. With the order of these curves you can determine if the curve is drawn over the marker or not.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,914 Views)
Hello Matthias,
Your workaround did well. Thank you. But in my opinion such a function would be practical.
Thank you again.
Patrick
(3,908 Views)
Hello Patrick!
You are right! IMHO some other practical functions are also mising for many yearsSmiley Sad
Matthias
Matthias Alleweldt
Twigeater?
(3,870 Views)
