DIAdem
Hint: Unicode Problem Diadem 9/ WinXP vs Diadem 8/WinNT
If You try to open datafiles from a Diadem 9/ WinXP system with an older version,say 8.0 / WinNT, You will receive an error message " Keyword 'ypD' not in list" or similar.
To solve this, make sure that the .dat-file is written in ANSI not Unicode in the FileWrite-Options-Dialogue.
(3,444 Views)
It's normal that you get this error, because Diadem 8.1 was the first version of Diadem which supported Unicode
(3,444 Views)
