DIAdem
Horizontally Centering Report Objects via Script
Hello
I wanted to be able to programmatically center report objects, such as a text box and a 2D curve plots, with each other.
DIAdem 2015 SP2 32 bit
Tim
(3,029 Views)
Accepted by topic author smoothdurban
Center objects in Sheet center:
Dim oCtrl, PageWidth, ObjWidth
PageWidth = Report.ActiveSheet.Dimensions.Width
for each oCtrl in Report.ActiveSheet.Objects
	ObjWidth  = oCtrl.Position.ByCoordinate.Width
	oCtrl.Position.ByCoordinate.X1 = PageWidth / 2 - ObjWidth / 2
	oCtrl.Position.ByCoordinate.X2 = PageWidth / 2 + ObjWidth / 2
next
call Report.Refresh()
 Center objects at center of another object:
Dim oCtrl, CenterPos, ObjWidth, RefObject
set RefObject = Report.ActiveSheet.Objects("TextObject1")
CenterPos = RefObject.Position.ByCoordinate.X1 + RefObject.Position.ByCoordinate.Width / 2
	if not oCtrl is RefObject then
		oCtrl.Position.ByCoordinate.X1 = CenterPos - ObjWidth / 2
		oCtrl.Position.ByCoordinate.X2 = CenterPos + ObjWidth / 2
	end if
next
Christian
CLA, CTA, CLED
(2,999 Views)
