DIAdem
How Do I Combine 10 Variables Into One New Channel of Data?
Hi:
Suppose I have a script that finds the maximum values of 10 different spots in a set of data.  Each time it finds a new maximum, it saves it to a variable.
How do I combine those 10 variables into a new channel of data?  For example:
Row
Value
1
10
2
20
3
30
4
40
5
50
6
60
7
70
8
80
9
90
10
100
(3,959 Views)
Hello Gatsby,
Here is some code that will create a new channel and write the value of the variable Peak01_Ch02 into the first row of the newly created data channel.
This code assumes there is at least one channel group in the data portal already.
Dim Peak01_Ch02, ChObj
Call Data.Root.ChannelGroups(1).Channels.Add("Channel",DataTypeFloat64,1)
Set ChObj = Data.Root.ChannelGroups(1).Channels("Channel")
ChObj(1) = Peak01_Ch02
You can easily put the channel object into a loop to fill multiple rows of the channel ...
Hope this helps,
     Otmar
Otmar D. Foehner
(3,956 Views)
