DIAdem
How can I count channel's number in diadem?
I need to know the number of channels in a file. I use a bucle like:
NumCh_=0
Do While CHNLENGTH(NumCh_+1)>0
NumCh_=NumCh_+1
Loop
But I'm sure that it is a instruction to get the number of channels. Can you help me?
(4,446 Views)
There is the global variable "ChnNoMax". But i think, that's not what you are looking for. You are looking for channels with "content", so channels with a length > 0 ?
If so, you have to check all channels in a loop similar yours, because its possible that emty channels are in the middle.
And you have to descide your looking for the number of filled channels or the index of the highest filled channel. That's a difference.
bohm
(4,446 Views)
Hi Radurdin,
As "bohm" mentioned, you might be interested in the channel number of the last channel with any values in it. There is an easy way to get that-- the DIAdem variable
GlobUsedChn
always stores the channel number of the last channel with data in it. It can happen that there are smaller empty channels prior to the channel number returned by GlobUsedChn, but usually the channels before it are all full.
Also, you say you want to know how many channels there are in a file, but then you start a loop over the channels in DIAdem. If you really want to know how many channels there are in a file, without having to load them into DIAdem, this is possible for some files with an easy set of commands and for all files with a hard set of commmands.
Finally, in DIAdem 9.0 and later you can also get the number of channels in any group with the
GroupChnCount(GroupIndex)
variable, and the number of available Groups with the
GroupCount
variable.
Brad Turpin
DIAdem Product Support Engineer
(4,446 Views)
This is teh instruction i was looking for. thanks
(4,446 Views)
