DIAdem
How can I define the position of a SUD dialog in Diadem-AUTO?
In the COD dialog-editor you can define the X- and Y-position of every dialog-window. In the SUD dialog-editor these options are not available. Is there any way to specify the position of a SUD dialog?
(5,482 Views)
Hi Johannes,
There are two parameters in the dialog properties called "Top" and "Left" that seem to deterine the position of the upper left corner of the dialog on the screen.
I have only used them in the "Preview" window of the SUD editor, but they seem to work fine.
Let me know if this is what you were looking for.
Otmar
Otmar D. Foehner
(5,482 Views)
Hi Otmar,
thank you for your answer. These two parameters would be fine, but they are not listed in the dialog properties. Maybe you have a later Version of the SUD-editor? I´m working on V 1.0.0.6 (at the moment I´ve only got the eavaluation version of DIAdem, but next week I´ll get the full version).
Could you please tell me what SUD version you use?
Thank you very much
Johannes
(5,482 Views)
Hello Johannes,
I am using the SUD editor that came with version 8.1 of DIAdem. In the "About" menu of the SUD Editor, the version number is displayed as 8.10.1292.
It also says Copyright 2002 by National Instruments Ireland.
Is is possible that you have an older evaluation version?
Otmar
Otmar D. Foehner
(5,482 Views)
Hello Otmar,
my DIAdem Edition is V8.00.981 (c)2001 including SUD Editor V1.0.0.6 (c)2001.
That´s the fault. So with the full version I´ll get next week the problem should be solved.
Thanks a lot for your answers
Johannes
(5,482 Views)
