DIAdem
How can I make a command to calculate the average
I want to create a command in a script. I have different files with different number of measurements. So in one file I've got for example six variables and in another nine. I want to make a command so it can calculate the average of the variables, but I want to use this formula in a script, I cannot just say (R1+R2+R3....)/9 because of the different numbers of variables. Can anyone help?
(4,440 Views)
Hello RAJH!
I like to help you but I do not understand your exact situation. Can you please tell me what kind of files do you have. Are these measurement data files (*.dat/*.tdm) or something else? You used both terms.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,414 Views)
Hello Matthias,
Thank you for replying!
I am working with *TDM files. I am writing a script to automize a couple of calculations, because I have to calculate over a hundred files.The data acquisited are "time", "speed" and "distance". These measurements are recorded from braking tests un dry surface where the driver of the vehicle speeds up to 110 km/h and then starts braking. The data starts recording from 100 km/h till 10 km/h. For this I have written commands to find the distance travelled at 60 km/h and saved these as variables R. I used the formula:
R1=CHD(Find("'Speed 1'<60"), "Distance 1")
The problem is that some tests have 8 repeating measurements and other test have only 5. So in one file I accuire 9 different variables and in the other only 6. I have to calculate the average brakingdistance, but I want to do this with a command to put these averages in a tabel in the report.
Also a problem i have encountered is that I have repeated the formula above for the other Variables (R2-R9), but as i was saying some files only have 5 repeatings and therefore the program gives an error. It doesn't recognize "Speed 7" cause there isn't. Maybe you can help me solve this as well.
Greets,
Robert
(4,420 Views)
Hallo RAJH!
One approach is to use the RV1 real variable vector instead of the Rx variables. Then you can use L1 as a counter.
Example:
Dim i
' fill (demo)
L1 = 4
RV1(1) = 1.234
RV1(2) = 2.345
RV1(3) = 3.456
RV1(4) = 4.567
' calculate sum
R1 = 0
For i=1 to L1
  R1 = R1 + RV1(i)
' calculate average
R1 = R1 / L1
MsgBox "Average = " & str(R1,"ddd.dd")
Note: The maximum value count for RV1 is 15!
If this doesn't suits you have a look at the DIAdem FormulaCalc command. This command can calculate expressions from a string.
Matthias
Matthias Alleweldt
Twigeater?
(4,406 Views)
OK thank you very much, this helps a lot!
greets,
Robert
(4,377 Views)
