DIAdem
How can I move 3D models in INSIGHT with Labview
hi~!!
I don't know how to assigne the coordinate..
I have read a Help topics..
There is ..
Assignment of points to a new, local coordinate system:
Follow the procedure described below to assign points to the local coordinate system:
  1. Mark the points that you wish to assign to the local coordinate system. To do so, click an individual point, with the ALT-key held down at the same time, or with the CTRL-key held down, draw a rectangle over the corresponding point.
  2. Click with the mouse on one of the points and drag the points to the origin of the local coordinate system. During this process, the cursor shape changes accordingly.
  3. Release the mouse at the desired position. The points are now assigned to the local coordinate system.
According to above mention, i was programing but the object don't move..(Luckly,coordination move~!!)
Could you please explain the my problem..
Thanks in advance!!
LEE
Message 1 of 1
(3,997 Views)
