DIAdem
How can I test DIAdem edition (Base/Advanced/Professional) feature differences programmatically?
I am building an application based on DIAdem, and I want to test and confirm that it will work within the feature limitations between DIAdem Base/Advanced/Professional editions.  What options exist (if any) that allow me to run my application (VBScript) within each of the different DIAdem editions?
(1,264 Views)
Hi markwkiehl,
If you encapsulate all the functions in a VBS script, you can run your application in all editions.
But maybe this is of interest for you:
msgbox "Version: " & programversion
msgbox "Revision: " & programrevision
MsgBox "Build No: " & ProgramBuild
' since DIAdem 2010
msgbox "Version name: " & ProgramVersionName
' since DIAdem 2012
msgbox "atfx - DataPlugin Version: " & navigator.Settings.RegisteredDataPlugins("atfx").Version
' since DIAdem 2014
msgbox "Bitness: " & ApplicationBitness
Greetings
Walter
(1,244 Views)
