DIAdem
How do I automate the file path to export to
I am trying to export to pdf without dialog but want the pdf to go to a file path that exists in the file properties of the TDMS data set that is loaded. I have also wrote it as a channel as well. I cannot get this to work.
' create PDF
Dim
PDFFile : PDFFile = ch([1]/SI PDF Path)
PrintLeftMarg
= 0.23
PrintTopMarg
  = 0.23
PrintWidth
    = 8
PrintOrient
   = "portrait"
On
ErrorResumeNext
Call
PicPDFExport(PDFFile)
If
(Err.Number <> 0) Then
CallMsgBoxDisp("Cannot create the PDF document.")
else
' show results in PDF reader
IfFileExist(PDFFile) ThenCallExtProgram("", PDFFile)
IfErr.Number <> 0ThenMsgBox"Cannot start the PDF Reader. Have you installed a PDF Reader on your computer."
End
If
Err
.Clear
On
ErrorGoto0
Message 1 of 8
(5,848 Views)
You can find the path with the following property
Data.Root.ChannelGroups(1).Channels(1).Properties("sourcedatafilepath").Value
To get this line you can drag&drop the property from the DataPortal into the workspace of SCRIPT.
I hope this helps
Winfried
Message 2 of 8
(5,846 Views)
I have tried dragging from the properties which gives me
Data.Root.Properties("SI_PDF_Path").Value
And dragging the channel gives me
Data.Root.ChannelGroups(1).Channels("SI PDF Path")
Both do not work for me.
Message 3 of 8
(5,844 Views)
The following line does not contain any channelname and works if you have at least one channel. It returns the path of the first channel in the first group:
Winfried
Message 4 of 8
(5,839 Views)
Thanks for helping me.
I am sorry if i am not understanding this but I know the path to my data channel ([1]/ SI PDF Path). I want to get this channels value (which is a string- C:\Data\Name of file) and set it equal to PDFFile in the above script.
If I use PDFFile= ch("[1]/SI PDF Path") - my result path is the numeric data index of the group and not the string value. I suppose because I got this from the calculator. But it is the only thing that remotely works for me.
Message 5 of 8
(5,837 Views)
I am still not sure if I understand you. You store the filepath in the first value of the channel "[1]/ SI PDF Path"
To get this value use:
Data.Root.ChannelGroups(1).Channels("SI PDF Path").Values(1)
But why do you store the path as channel value? There are default properties that contains the path.
Hope this helps
Winfried
Message 6 of 8
(5,834 Views)
I am storing the filepath that i want the pdf to be exported to. I have wrote this path as both a channel (called SI PDF Path) and a file property. The channel has one value - the path to export the pdf document to.
Message 7 of 8
(5,831 Views)
Accepted by topic author Chris_Co
I finally figured it out.
The script should look like:
Dim PDFFile
PDFFile = Data.Root.Properties("SAE_PDF_Path").Value
The colon was screwing it up and moving it to the second line.
Message 8 of 8
(5,826 Views)
