DIAdem
How do I call DIAdem from LabVIEW, specifying a template and a data file?
Using LV 7.0, want to open a reference to DIAdem, specifying a template and a data file.
(3,954 Views)
To make LabVIEW talk to DIAdem, please download the following FREE toolkit, which adds a DIAdem palette to your LabBIEW software and includes some examples for the different functions included in the toolkit.
http://digital.ni.com/softlib.nsf/954feaeea92d90918625674b00658b83/a2ad1d0c68740d7c86256c55004e4e58?OpenDocument
Please let me know if you have any additional questions about this toolkit.
Otmar
Otmar D. Foehner
(3,954 Views)
To be specific,
With the 2.1 LabVIEW-DIAdem Connectivity VIs there is a LabVIEW 7 Express Block called "NI DIAdem Report Wizard" which takes as inputs a path to a data file and a path to a report template. When run, this Express Block will automatically load your data set and apply the selected report template to create the desired report in DIAdem.
There is also a LabVIEW 6.1 VI which does the same thing if you have the 2.1 Connectivity VIs and LabVIEW 6.1.
Brad
(3,954 Views)
Thank you, FYI my confusion was that a 'layout' is the same as a 'template' in DIAdem.
JH
(3,954 Views)
