DIAdem
How do I change a .tdm/.tdx from a channel-oriented structure to block-oriented?
I am using DIAdem to post-process data and need to be able to feed it back through a Matlab script. I've figured out how to deal with the data itself and make it waveform/block data, but every time I save the new .tdm/.tdx file, it comes out as "channel-oriented" in the Include Block. When we get the data from LabView, it is always "block-oriented" so that's how the script reads in the information. How can I change the output file's structure? (When I pull the data into DIAdem, I pull it from the LabView block-oriented file.)
(4,337 Views)
There is no way to force the mode of TDM file.
(I assume that you use the header writer VI in LabVIEW which is the only one letting you decide)
I would suggest using the DDC lib to access the tdm/tdms data from 3rd party tools.
https://forums.ni.com/t5/Example-Code/Reading-TDM-TDMS-Files-with-The-MathWorks-Inc-MATLAB-Software/...
(4,298 Views)
