DIAdem
How do I create a user dialog box with check boxes in order to run functions that were created in a script?
I have created a script that has several functions.  I want to have a user dialog box pop up so that the user can use check boxes to select different functions in order to run these functions.
(3,654 Views)
Hello jreynolds!
The simplest way is to create a SUD dialog with DIAdem and use the standard boolean values. I attach an example wich you can examine and adapt to your needs.
Feel free to ask if you need further help
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,645 Views)
Thanks, I was making it a lot harder than it is.
(3,639 Views)
