DIAdem
How do I find at what index the max value occurs for a channel?
I may be overlooking something very simple here but I need to find out at what index the max value occurs for a channel.  I need the index so I can look up other data at the same index in a script.  Sorry for asking what is probably a newbie question.  Thanks.
(6,579 Views)
Hi ric.winters,
Please use the function PNO, which returns the index of a given value in a channel.
Greetings
Walter
(6,570 Views)
Hello ric.winters,
As an example to explain the recommendation made by Walter, here is a little bit of code:
L1 = PnO("Speed",CMax("Speed"))
msgbox(L1)
L1 is a user variable (longinteger) provided by DIAdem
PnO determines the row in a numeric channel or a text channel, of which the contents are closest to a specified value or text
CMax is a variable that contains the maximum value of a channel
MsgBox generates a message box
The code above will store the index number of the maximum value of the channel called "Speed" in the varibale L1 and subsequently displays that value in a message box.
Otmar D. Foehner
(6,564 Views)
