DIAdem
How do I get the error on fit parameters in Diadem
I am using Diadem "linear least-square fit" with weighted Y-channel. The typical fit model is y=a+b*x. Here is my question:
How do I get the error on the fit parameters a and b ?
Okay, I can ask Diadem to calculate the co-variance matrix, and then use a script to calculate the errors, but there must be a short-cut?
BR,
Chr
(4,210 Views)
Hi schoric,
The only quantitative regression fit assesment that is built into the DIAdem function is the coefficient of determination of the regression (r^2), which is stored in the global DIAdem variable:
RegrPrecision
Does that help?
Brad Turpin
DIAdem Product Support Engineer
(4,204 Views)
Hi Brad,
thanks for the quick answer ! ...although I had hoped I could do some easy trick....
BR,
Chr
(4,183 Views)
