DIAdem
How do I plot a y axis on the left and right in DIAdem/VIEW (version 11.0)?
I am trying to analyze flight data, and I would like to analyze plots of certain parameters so that they share an x axis. It is necessary to view these using two different y axis, on the left and right. How do I do this in DIAdem (version 11.0) in the VIEW tab? Is this possible to do in the VIEW tab?
Message 1 of 8
(7,000 Views)
Hello Myocom,
Multiple Y-axes in VIEW are supported since DIAdem 11.1 (in DIAdem 11.0 the closest thing is Y-Axis [%] setting).
All Y-axes in DIAdem VIEW will appear on the LEFT side, there is no setting to make them appear on the left and right (see screenshot below).
You can arrange Y-axes in DIAdem REPORT with a lot more flexibility (multiple Y-axes on the left and/or right), in VIEW we can display Y-axes only on the left side of the axis systems.
I hope this helps,
     Otmar
Otmar D. Foehner
Message 2 of 8
(6,991 Views)
Is it possible to select a min/max point with the mouse and have the x,y corrdinate plotted (in 11.0)? I know that you can scan through and then click on the "coordinates" icon, but this doesn't put the coordinates on the point itself and is a bit tedious. Does 11.1 offer the capability to use this basic graphing selection tool?
Message 3 of 8
(6,988 Views)
Hello myocom,
Since I have no understanding of your ultimate goal for this application, I will point you to an example that shows what you might be looking for:
This report was created using the example called: AnalyzeWaveformChannels from the DIAdem Help System. You can find out under "Help > Examples > Creating Scripts > Scripts > Calculating with Waveform Channels"
This example shows how to use the ChnPropValGet command to specify the minimum values and the maximum values of waveform channels. You use the PNo function to specify the line number of the extreme values and the ChDWfX variable to specify the X-value. DIAdem displays the result in a report.
DIAdem-VIEW does not display coordinates in the windows (only at the current cursor position). The correct place to do this is the REPORT window.
If you can be more specific about the application you are looking to solve, I would be happy to look into this further ...
      Otmar
Otmar D. Foehner
Message 4 of 8
(6,979 Views)
What if it is just a random point? Is there no selection tool I can use to simply select and label a point automatically? (Like the "data cursor" in MATLAB, for instance.)
Message 5 of 8
(6,958 Views)
myocom,
You can highlight random points in DIAdem as well.
Here is an example:
  1. Use the cursor to move to the point you wish to highlight.
  2. Press the "Set Data Point and Flag" icon on each data point you wish to highlight
  3. When you are done selecting points, press the "Flags: Copy Data Points" icon - that will copy all X/Y coordinates into two new channels
I created a REPORT Layout using the original data and the highlighted random points (I added the actual point Z-value above the point, they look strange when written at the exact point). I attached the layout for your reference.
The complete task took 3 minutes from loading the data to finishing and exporting the REPORT layout. If you have a REPORT layout already, this will take less than 30 seconds ...
I am not familiar with Matlab, so I can't compare how this works in DIAdem vs. Matlab. You can add the combine the complete process in a Script and it will automatically create this kind of report after simply selecting a few data points in VIEW and then pressing a button ...
    Otmar
Otmar D. Foehner
Message 6 of 8
(6,954 Views)
After some working with it, I was able to get something similar to your graph. Is it possible to do this over a series of graphs when plotting n-systems? (I could only get this way to work when I had one plot). Also, how do I display the x-value? I can only get it to label the y value (as you have). Finally, when I put in the flag(s) and transfer the coordinates, it displays them as constants at first. I had to manually merge the x and y together, then put them as a coordinate, etc... What process do I use in order to display them as an x,y point automatically instead of having to do this manually in the "Curve and Axis Definition" menu?
Message 7 of 8
(6,941 Views)
Hello myocom,
It seem to me that we are slowly moving forward on your questions with each post here, but I still don't understand what exactly you want to do.
In order for me to be able to help you with your specific questions, it might be best to speak on the phone rather than post another 20 questions and answers.
Please call (888) 280-7645 (I assume you are in North America) and ask to be connected to me. That way we can speak directly and I can understand your task and provide a solution.
Otmar D. Foehner
Message 8 of 8
(6,919 Views)
