DIAdem
How do I reverse a logarithmic x-axis scale in DIAdem Report?
I am trying to reverse the logarithmic x-axis scale for a 2D graph in Report - how can I do this?
I would like my scale to start at 50 and end at 1.
(3,149 Views)
Hi a_r_s.
As of DIAdem 2017 (currently in Beta), there is no way to natively display an X or Y axis in REPORT as BOTH logarithmic AND inverted.  The closest you can get is to choose inverted and then create a new channel with the Calculator that contains the logarithmic results.  You'll then need to change the axis label to let the user know they're looking a Log values, because they'll display as regular numbers without the built in logarithmic display option.
Brad Turpin
DIAdem Product Support Engineer
(3,112 Views)
