DIAdem
How do I step through functions in ScriptInclude
We have a library of functions that we include with the "ScriptInclude" command. While single stepping with the debugger, the debugger will step through the functions in the included file. Anyone know a way around this? thanks
(3,654 Views)
Hi Tony!
If you WANT to single-step (using "Step into") through functions that your script calls, then the VBS file containing those functions should be open in the DIAdem-SCRIPT editor. When you "Step into" those functions from your script, the DIAdem-SCRIPT debugger will display the file and show the yellow execution-arrow for you.
If you DO NOT WANT to step through those functions, then don't open that particular VBS in DIAdem.
I hope things are going well for you and Jacob!
David Mc.
NI Applications Engineering
(3,654 Views)
