DIAdem
How do I stop a dialog editbox from giving an error when all numbers are removed
When using an editbox in a SUD the box initialises with a variable. Then I would like to change the value in the editbox which works ok unless the editbox is cleared completely, then an error occurs because the R variable cannot be prescribed as zero.
I think that it is just a case of refreshing the contents when I leave the SUD. I press a button.
The text looks like this for the editbox.
Sub Editbox6_EventInitialise()
Dim This : Set This = Explanation
this.text
(3,715 Views)
Sorry, hit post button by accident.
this is the rest of the script.
Sub EditBox6_EventChange()
Dim This : Set This = EditBox6
            R10 = this.text
End Sub
Sub EditBox6_EventInitialize()
            this.Text = R10
End Sub
Stagsden
(3,714 Views)
Hi Stagsden,
This is a VBS problem in general. The Type of Rx variables are explicit Double and the Edit.Text is a variant with the sub type string. If you assign something like R1 = edit.Text VBScript tries to convert a string into a double type. That works if the string is a regular numeric string like 12 or 3.13 - but it fails in case of a empty string (""). You can check that in the DIAdem SCRIPT editor like:
Dim t
t = "12"
R1 = t
msgbox R1
and
t = ""
R1 = t
msgbox R1
We have an example  which shows how to handle such stuff and it shows how you can check the entry. Please have a look at "Checking Dialog Box Entries"
Greetings
Walter
(3,698 Views)
