DIAdem
How do I stop ddatafinder from loading automatically?
I put datafinder on a machine with multiple users many of whom will not be doing anything with Diadem and I would like to be able to eliminate the datafinder for those users.  Where do I go and what do I do to turn off the associated services that shows up in my system tray as a yellow circular icon?
(8,559 Views)
Hello deserio,
The following steps will turn off the auto-start of the DataFinder:
  • Press and hold the WINDOWS key and then press "R"
  • A dialog will pop up. In this dialog, type "msconfig" and then click the "OK" button
  • The MicroSoft System Configuration Utility dialog will appear on your screen
  • Select the "Startup" tab
  • Scroll until you find the "DataFinder" entry and uncheck the box in front of the DataFinder text
  • Click "OK"
  • The System Configuration tool will ask you to restart Windows. Make sure all your work in other applications is saved and select "Restart"
  • Done
From now on, the DataFinder will not start with Windows.
Hope that helps, let me know if you have any more questions,
    Otmar
Message Edited by Otmar on 07-27-2009 05:20 PM
Otmar D. Foehner
(8,553 Views)
Is there a way to fire up datafinder when some users login but not when others log in?  Where is it getting started from?  Is it from the registry entry HKEY_LOCAL_MACHINE \ Software \ Microsoft \ Windows \ CurrentVersion \ Run (where I see the datafinder.exe with a /auto)?
(8,537 Views)
Hi deserio,
What you can do is drag a shortcut to DataFinder in to the Startup folder for each user you want to have the program start up for.  On an XP machine, this is located at: C:\Documents and Settings\USERNAME\Start Menu\Programs\Startup.  I hope this helps!
Cheers,
Kelly R.
(8,516 Views)
That would be a much preferred alternative.  Can I then go ahead and remove the LOCAL MACHINE registry entry?
(8,505 Views)
Hi deserio,
I think it would be best if you followed the steps that Otmar suggested to stop the auto-start of DataFinder.  I would then move the short-cut to the DataFinder into the Startup folder for the desired users to see if this works for you.  Generally we do not recommend deleting files from the registry.
Cheers,
Kelly R.
(8,491 Views)
