DIAdem
How do I use block functions with a file that has channel names in the rows
I hope the title isn't too confusing, but I have data in the format shown below:
Chn_1    1      2      3      4      5
Chn_2    a      b      c      d      e
Chn_3    1.1   2.1   3.1   4.1   5.1
Chn_4    1      2      3      4      5
I want to be able to use the GetCellBlockor or GetStringBlock with this data, but it seems to require that the channel names are going across the columns instead of down the rows.
Does anyone have a clean way grab these channel and add them with the correct data type to the data portal?
(2,947 Views)
Hello Kevin_McG,
Would you mind posting how you are attempting to use these calls? I want to see if I can recreate something over here and mess around with the calls.
Best,
Danielle
(2,918 Views)
Accepted by topic author Kevin_McG
There is no way to use the stringblock directly but you plugin code could look like this just using the build in parser to help.
Data
Chn_1    1      2      3      4      5
Chn_2    a      b      c      d      e
Chn_4    1      2      3      4      5
Plugin Code
Option Explicit
Sub ReadStore(File)
  File.Formatter.Delimiters = " "
  File.Formatter.LineFeeds = vbNewLine
  file.Formatter.TrimCharacters = " " ' trim the spaces
  File.Formatter.DecimalPoint = "."
  Dim ChannelGroup : Set ChannelGroup = Root.ChannelGroups.Add(File.Info.FileName)
  do
    dim channelName : channelName = File.GetNextStringValue(eString)
    if isEmpty(channelName) then
      RaiseError ' This file has a different format
    end if
    ' use the first value to determine the datatype of the channel
    dim channelValue : channelValue = File.GetNextStringValue(eString)
    dim channelDataType : channelDataType = eR64
    if(0 = file.Formatter.ParseString(channelValue,channelDataType) AND "" <> file.Formatter.ParseString(channelValue, eString)) then
      channelDataType = eString ' value is not numeric so we load it as string
    end if
    dim chO : set chO = ChannelGroup.Channels.Add(channelName,channelDataType)
    dim i : i = 1
    cho.Values(i) = file.Formatter.ParseString(channelValue,channelDataType)
'    ' add the remaining values by looping till the line is eaten
    channelValue = File.GetNextStringValue(channelDataType)
    do while NOT VBEMPTY = VarType(channelValue)
      i = i + 1
      cho.Values(i) = channelValue
    Loop
  Loop until NOT File.SkipLine
End Sub
(2,911 Views)
