DIAdem
How do you transfer the actual data from Diadem to Excel
Using Diadem as an OLE server, how would you transfer for example: Ch(1) to ExcelSheet.Range("B5:B1700")? Do you have to do it one value at a time or can you do a block transfer?
(4,379 Views)
You can copy a whole diadem channel (or only a part of it) into the clipboard and then paste it into a selected area of excel. You can open the excel-application from diadem. Then open a worksheet, select a cell and paste the channelcontent you have copied before.
(4,379 Views)
The DIAdem.ToDatasheet offers functions to export an data area (ValueRangeGet and ValueRangeFormatedGet). This allows you to store all data of a certain area in vector variables.
Unfortunately it seems that Excel does not support a similar method to set a data area. Allthough you can mark a range to change properties of a number of cells at the same time I think you will have to set the value of each cell individually.
I found some lines in a vb-example that might help you:
'Add data to the spreadsheet. The data is input to Excel one point at a time,
'by going stepping through the array one point at a time, and placing it in
'its assigned cell. The cell location is determined by converting the column
'index of the array into an a
scii value, and adding 65. So the first column
'of data fills to the ASCII equivalent of 65, which is "A". Note that this
'is only valid for columns A through Z, but since data acquisition rarely
'takes place on more than 16 channels, the limit is not restrictive.
For x = 0 To numchannels
For y = 0 To numscans
.Range(Chr(x + 65) + CStr(y + 10)).Value = ScaledData(x, y)
(4,379 Views)
Thanks d.s. , I feel like I should have known that.
(4,379 Views)
This is the correct procedure to implement this data transfer.
Diego Reyes
Applications Engineering
(4,379 Views)
Thanks, this works, although the data loads rather slowly but I can live with that.
(4,379 Views)
