DIAdem
How does DIADEM import TDMS files? How gets every channel his number and groupindex? How can I determine which channel has which groupindex and number?
Thanks Herbert,
but the TDMS Flush VI doesn't work.
If I use the flush TDMS VI the order is the same like without and still wrong.
But Ingo detected, if I swap the order of the sequence frames and write the time channel last it  will be the first channel in Diadem.
Ciao Joerg
Message 11 of 11
(935 Views)
