DIAdem
How to Add channel property as DataTypeFloat64
Hi, I would like to ask about how can I create a Diadem property as a DataTypeFloat64.
I tried something like, following example, but It not works:
Dim prop
Set prop = Data.Root.ChannelGroups("Measurement").Properties
Call prop.Add("__w001_AverageVoltage", 0,DataTypeFloat64)
THX for help.
(3,015 Views)
Call Data.Root.ChannelGroups("Measurement").Properties.Add("__w001_AverageVoltage", 0, DataTypeFloat64)
(2,990 Views)
Hi steelbull,
Your script code works fine with my DIAdem (tested in version 2018, 2017 and 2015). I’m pretty sure the problem is not the property setting itself. To find the error I need more script content.
Greetings
Walter
(2,984 Views)
Current DIAdem versions seems to be O.K. with your code.
Option Explicit
Dim prop
Set prop = Data.Root.ChannelGroups(1).Properties
Call prop.Add("__w001_AverageVoltage", Cdbl(0),DataTypeFloat64)
will convert your integer to double which the error seems to complain about.
(2,977 Views)
